DISCOUNT PRICE!
Seplos hat einige neue DIY-Kits für die meistverkauften LFP-Zellen auf dem Markt entwickelt.
Busbars mit doppelten Löchern für EVE LF280K Grade A
Seplos new vertical-type DIY kits for 280Ah cells. It fits less space room.
@jerry-seplos Hi Jerry - whats your idea about the pricing?
How to - Akku China Shopping
@arc we have price gradient for different order quantity? like wholesale price and distributor price
@jerry-seplos would you mind to publishing here?
For fishing you do need to offer a bite😜
hello, are the new Seplos new vertical-type DIY kits for 280Ah cells also with yellow spacers and is it compressed and do it work together with the new terminals for the
Eve
battery
thank you
Eve
battery
thank you
what is your message? Don’t get it.
finger weg von gehäusen mit liegenden zellen
will the new Seplos new vertical-type DIY work with Busbars mit double whole für EVE LF280K Grade A ?
Please see the post from March 14, there it is explicitly stated. (With picture)
Cheers
Eclipse
Installation:
Geplant: Gartenhütte mit ca. 5kWp - Frühjahr 24
@schwuppe This MASON280 DIY box is suitable for EVE280K/280/304, CALT/CALB/LISHEN280 cells, and other cells that have similar dimensions (72mm*174mm*202mm)
@schwuppe yes, it is also compatible with EVE280K with double holes terminals
