Habe gerade folgende Nachricht von Hoymiles bekommen?
Weiß jemand mehr ueber diese Wechselrichter?
LG
T
Hoymiles next-gen line of hybrid inverters debuted on September 15, expanding our range of advanced energy solutions.
Hybrid solar systems involve the use of solar panels, batteries, and the main grid, as well as generators in some cases for added reliability. The two-way conversion of electricity from alternating current (AC) to direct current (DC) as well as DC to AC allows the hybrid system to dynamically switch between power sources depending on energy production, price, and usage.
Our hybrid inverters are available in single-phase (HYS series) and three-phase (HYT series) options, with a custom-designed data transfer stick (DTS) to gather and transmit operational data of the system to the S-Miles Cloud monitoring platform.
Here are the major highlights of our new inverters:
Wide power range from 3 to 12 kW to get you covered for whatever needs
Industry-leading 1.5 DC/AC ratio: significantly lowering cost when compared with systems of the same capacity using other inverters
14A Maximum Power Point Tracking (MPPT) current: seamless compatibility with all mainstream photovoltaic modules
Unmatched 97.6% efficiency: optimal solar harvest for the best cost-effectiveness
Intelligent Energy Management System (EMS): letting you decide how you’d like to use your own power
Lightweight, compact, and simple to install
