hallo hier ist mein problem keine kommunikation mehr auf meiner seplos v16 pcb karte mit bluethoo funktioniert es und eines tages nichts mehr unmöglich mit 2 v16 pcb karten zu kommunizieren keine rx kommunikation auf dem cerbo alles ist in 19200 und kabel ok adapter ok hatte probleme kommunikation und wenn ich die Firmware ändern will, geht das nicht!!! Danke euch allen
So kann man nix lesen. Versuch es doch mal mit plain text
How to - Akku China Shopping
nicht verstanden, weil die Übersetzung und nicht klar ist
@xenonfoxone do you use RS485 or CAN bus as com protocol?
or is your problem the communication between BMS and notebook?
How did the failure arose? Just out of the blue or did you change something?
I have another pcb v16 and no problem it communicates with the software and cerbo and I change the pcb to put other and no more communication rx nor with the software and cerbo nothing if I put other everything is ok !!! so it doesn't come from the cable or adapter!!!
CAN 19200 bus protocol for my cerbo and the 19200 software with on the conector RS485 in
Pls do not cut HTML text or similar and paste it into here.
This pasting is wrong formatted and not really readable.
if you paste - than just plain text please
ok
@xenonfoxone I understood that you have two BMS. One is working well the other one does not communicate. Is this correct?
i also understood that you found this out by replacing one BMS with the other, right?
I'm sorry, I'm new to the forum, I'm not used to going to a German forum and translating, thank you again for your indulgence
This is what I see on my smartphone when you paste something different than plain text!
How to remove text format
